Open Builds Black Box Limit switches
Discussion in 'CNC Mills/Routers' started by contacto75, Jan 3, 2022.
  1. contacto75
    Hello,
    I´m trying to connect my limit switches to my new black box and the pboblem I´m having is:
    The switches stop 2 times, when it touches and when it releases, can anyone help?
  2. Christian James
    Christian James Journeyman
    Do you mean that when the carriage hits the switch, it pulls back from the switch, then contacts the switch again? If so, that's what it's supposed to do to correctly home.
  3. contacto75
    No, it stops as soon as it touches and it only moves if I click unlock alarm, then, when it releases the switch , it stops again
  4. Alex Chambers
    Increasing your pull off distance might solve this issue. What is your $27 value? If it's less than 10 try setting $27 to 10 and see if that fixes it.
  5. contacto75
    $27 is 5mm
  6. contacto75
    This is my switch, can you help by telling me where do I connect each wire in my black box?
  7. Alex Chambers
    As I said above, set $27=10. If that fixes it you can try reducing it until the problem recurs, then increase it slightly again.
  8. contacto75
    done it but same results, it touches and stops but do not retract nothing
  9. contacto75
    I´m not doing the homing, I´m doing a normal stop to prevent damage
  10. contacto75
    a video of it
  11. Alex Chambers
    You presumably have hard limits enabled, in which case that is normal behaviour - if a limit switch is triggered the blackbox will go into alarm mode - it thinks a limit switch has been hit (crash) and forces you to re-set everything.
  12. contacto75
    ok, understood, but why the two alarms? when touches and when releases?
  13. Peter Van Der Walt
    Order yourself some better switches: Xtension Limit Switch Kit
    Low quality switches "bounce" and those are garbage that also doesn't last.
  14. contacto75
    ok, how do I eneble the home all sequence? There is an error message:
  15. Peter Van Der Walt
    According to that screenshot, Homing is already enabled. But your switches did not clear when Grbl tried moving off them.
  16. contacto75
    no axis is touching the switches
  17. contacto75
    These are my settings at the moment
  18. Peter Van Der Walt
    Set $5 back to 0 please
  19. contacto75
    Problem solved, Thanks everyone for the tips snd tricks!
