OX CNC trouble
Discussion in 'CNC Mills/Routers' started by mirkojadric, Jan 15, 2021.
  1. mirkojadric
    I have a question about my OX CNC machine. I was drilling holes in my waste board for my clamps. I was tired of screwing my workpiece over and over to my waste board and destroying it. After the job was done i saw something is wrong. My holes were not in line, after the eight row they started to go to the left.
    After that I started to cut my clamps, the first one was perfect but the second one was a disaster. It oversteped 1" and went over another clamp. The blue line shows where it should go, and the red line shows where it went.
    My question is: Is something wrong with my steppmotors? Are my belts to loose, or too tight? Am I going too deep with my Z axe ( I'm using rules of thumb)? Is my router too weak (I'm using Makita rt0700c)?
    Thank you in advance!
  2. JustinTime
    JustinTime Veteran
    I would guess that one, or more, of your pulleys is loos. Check if all the set screws are tight.
  3. David the swarfer
    The X axis lost steps.
    Belts tight? (use a fishing scale to pull to 12kg of tension)
    Pulleys properly fastened with the grub screws, one screw on the flat of the shaft?
    Stepper Driver current high enough?
    Acceleration and/or maxspeed too high?
    and yes, after checking/adjusting everything you should also at least do a test cut with shallower depth of cut (and higher feedrate, make chips not dust).
  4. mirkojadric
    All set screws are tight.
