Slow plasma on. curves
Discussion in 'Laser Cutters' started by maxwcnc, Jan 5, 2025.
  1. maxwcnc
    maxwcnc New
    Hi Guys,
    Trying to cut a shaped washer cuts great on the circle but not on curved part bit new to this using fusion for drawing slow bit is formed by 7 points and connecting its from jpeg scanned in and calibrated.
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for Grbl 1.1 / BlackBox controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.37)
    (Units = mm)
    (Laser UseZ = false)
    (Laser UsePierce = false)
    (Arcs are limited to the XY plane: if you want vertical arcs then)
    (edit allowedCircularPlanes in the CPS file)
    (Drawing name : tiger headlight ring v1)
    (Program Name : tigerhl)
    (1 Operation :)
    (1 : 2D Profile5)
    ( Tool 1: Plasma Cutter Diam = 0.8mm)
    ( Machining time : 0h:1m:11s)
    G90 G94 G17
    G21
    (Plasma pierce height 2)
    (Plasma topHeight 0)
    (Operation 1 of 1 : 2D Profile5)
    G54
    (Plasma cutting with GRBL.)
    G0 X-49.043 Y64.81
    M3 S1000
    G4 P1.8
    G1 X-52.263 Y68.636 F1000
    G3 X52.263 Y-55.562 I52.263 J-62.099
    X-52.263 Y68.636 I-52.263 J62.099
    G1 X-49.043 Y64.81
    M5
    G0 X-70.77 Y89.438
    M3
    G4 P1.8
    G1 X-67.523 Y85.635
    G2 X74.656 Y-65.868 I67.523 J-79.099
    G1 X74.647 Y-65.878
    X73.793 Y-66.736
    X69.436 Y-73.441
    G2 X69.219 Y-73.679 I-0.839 J0.545
    G1 X65.797 Y-76.399
    X65.748 Y-76.469
    X65.625 Y-76.648
    X65.509 Y-76.815
    X65.401 Y-76.971
    X65.299 Y-77.118
    X65.203 Y-77.256
    X65.203 Y-77.256
    X65.028 Y-77.51
    X64.871 Y-77.737
    X64.729 Y-77.943
    X64.6 Y-78.13
    X64.483 Y-78.3
    X64.376 Y-78.458
    X64.276 Y-78.603
    X64.184 Y-78.738
    X64.099 Y-78.863
    X63.944 Y-79.092
    X63.806 Y-79.296
    X63.683 Y-79.481
    X63.571 Y-79.65
    X63.468 Y-79.807
    X63.372 Y-79.953
    X63.193 Y-80.231
    X63.026 Y-80.496
    X62.862 Y-80.761
    X62.692 Y-81.043
    X62.602 Y-81.192
    X62.508 Y-81.353
    X62.406 Y-81.526
    X62.296 Y-81.716
    X62.175 Y-81.926
    X62.039 Y-82.163
    X61.964 Y-82.293
    X61.885 Y-82.433
    X61.799 Y-82.584
    X61.707 Y-82.747
    X61.606 Y-82.925
    X61.497 Y-83.12
    X61.376 Y-83.334
    X61.243 Y-83.572
    X61.095 Y-83.837
    X61.014 Y-83.981
    X60.929 Y-84.134
    X60.928 Y-84.134
    X60.837 Y-84.298
    X60.74 Y-84.472
    X60.636 Y-84.658
    X60.524 Y-84.858
    G2 X60.222 Y-85.193 I-0.874 J0.487
    G1 X59.692 Y-85.561
    X59.692 Y-85.561
    X59.182 Y-85.916
    X59.182 Y-85.916
    X58.689 Y-86.258
    X58.213 Y-86.589
    X58.213 Y-86.589
    X57.753 Y-86.908
    X57.753 Y-86.909
    X57.308 Y-87.217
    X56.878 Y-87.515
    X56.877 Y-87.516
    X56.461 Y-87.804
    X56.461 Y-87.805
    X56.057 Y-88.084
    X56.057 Y-88.084
    X55.666 Y-88.355
    X55.666 Y-88.355
    X55.286 Y-88.618
    X55.286 Y-88.618
    X54.918 Y-88.872
    X54.918 Y-88.872
    X54.56 Y-89.119
    X54.56 Y-89.119
    X54.213 Y-89.359
    X54.213 Y-89.359
    X53.876 Y-89.592
    X53.548 Y-89.818
    X53.547 Y-89.819
    X53.229 Y-90.038
    X53.228 Y-90.039
    X52.918 Y-90.252
    X52.918 Y-90.253
    X52.322 Y-90.663
    X52.321 Y-90.663
    X51.755 Y-91.052
    X51.755 Y-91.052
    X51.217 Y-91.422
    X51.216 Y-91.422
    X50.704 Y-91.773
    X50.703 Y-91.773
    X50.215 Y-92.107
    X50.214 Y-92.108
    X49.748 Y-92.426
    X49.747 Y-92.427
    X49.301 Y-92.731
    X49.3 Y-92.731
    X48.873 Y-93.022
    X48.873 Y-93.022
    X48.463 Y-93.3
    X48.463 Y-93.301
    X48.07 Y-93.567
    X48.069 Y-93.567
    X47.692 Y-93.822
    X47.691 Y-93.823
    X47.328 Y-94.068
    X47.327 Y-94.068
    X46.978 Y-94.304
    X46.977 Y-94.304
    X46.64 Y-94.53
    X46.639 Y-94.531
    X46.314 Y-94.749
    X46.313 Y-94.749
    X45.999 Y-94.959
    X45.998 Y-94.96
    X45.695 Y-95.162
    X45.694 Y-95.163
    X45.401 Y-95.358
    X45.399 Y-95.359
    X45.115 Y-95.547
    X45.114 Y-95.548
    X44.839 Y-95.73
    X44.837 Y-95.731
    X44.57 Y-95.907
    X44.568 Y-95.908
    X44.056 Y-96.244
    X44.054 Y-96.245
    X43.57 Y-96.561
    X43.567 Y-96.563
    X43.108 Y-96.86
    X43.105 Y-96.862
    X42.667 Y-97.143
    X42.664 Y-97.145
    X42.247 Y-97.411
    X42.244 Y-97.413
    X41.844 Y-97.665
    X41.841 Y-97.667
    X41.457 Y-97.908
    X41.453 Y-97.91
    X41.083 Y-98.139
    X41.08 Y-98.142
    X40.723 Y-98.361
    X40.719 Y-98.364
    X40.373 Y-98.574
    X40.369 Y-98.576
    X40.033 Y-98.778
    X40.028 Y-98.781
    X39.701 Y-98.975
    X39.697 Y-98.978
    X39.378 Y-99.165
    X39.37 Y-99.17
    X38.751 Y-99.526
    X38.741 Y-99.532
    X38.14 Y-99.869
    X38.129 Y-99.875
    X37.54 Y-100.196
    X37.528 Y-100.202
    X36.944 Y-100.51
    X36.932 Y-100.517
    X36.346 Y-100.816
    X36.334 Y-100.822
    X35.739 Y-101.116
    X35.725 Y-101.122
    X35.113 Y-101.413
    X35.101 Y-101.419
    X34.463 Y-101.712
    X34.451 Y-101.717
    X34.119 Y-101.864
    X34.116 Y-101.866
    X33.774 Y-102.016
    X33.767 Y-102.019
    X33.413 Y-102.171
    X33.409 Y-102.173
    X33.042 Y-102.328
    X33.032 Y-102.332
    X32.649 Y-102.491
    X32.646 Y-102.492
    X32.245 Y-102.656
    X32.237 Y-102.659
    X31.815 Y-102.827
    X31.811 Y-102.829
    X31.366 Y-103.004
    X31.362 Y-103.005
    X30.891 Y-103.188
    X30.884 Y-103.191
    X30.382 Y-103.382
    X30.377 Y-103.384
    X29.84 Y-103.585
    X29.837 Y-103.586
    X29.553 Y-103.691
    X29.55 Y-103.692
    X29.256 Y-103.8
    X29.255 Y-103.8
    X28.949 Y-103.912
    X28.945 Y-103.914
    X28.626 Y-104.029
    X28.294 Y-104.149
    X28.291 Y-104.15
    X27.943 Y-104.274
    X27.942 Y-104.274
    X27.578 Y-104.403
    X27.576 Y-104.404
    X27.195 Y-104.538
    X27.194 Y-104.539
    X26.794 Y-104.679
    X26.792 Y-104.68
    X26.372 Y-104.826
    X25.929 Y-104.98
    X25.926 Y-104.98
    X25.459 Y-105.141
    X25.456 Y-105.142
    X24.962 Y-105.311
    X24.96 Y-105.312
    X24.436 Y-105.49
    X24.435 Y-105.49
    X23.878 Y-105.679
    X23.878 Y-105.679
    X23.586 Y-105.778
    X23.583 Y-105.779
    X23.282 Y-105.88
    X22.971 Y-105.985
    X22.97 Y-105.985
    X22.648 Y-106.093
    X22.315 Y-106.205
    X22.312 Y-106.206
    X21.967 Y-106.321
    X21.893 Y-106.342
    X21.617 Y-106.411
    X21.615 Y-106.412
    X21.35 Y-106.477
    X20.846 Y-106.604
    X20.843 Y-106.605
    X20.372 Y-106.721
    X19.932 Y-106.832
    X19.929 Y-106.833
    X19.514 Y-106.936
    X19.124 Y-107.033
    X19.123 Y-107.033
    X18.754 Y-107.124
    X18.408 Y-107.21
    X18.079 Y-107.291
    X18.077 Y-107.292
    X17.765 Y-107.369
    X17.765 Y-107.369
    X17.469 Y-107.442
    X17.189 Y-107.512
    X17.186 Y-107.512
    X16.918 Y-107.578
    X16.914 Y-107.579
    X16.66 Y-107.641
    X16.418 Y-107.7
    X16.185 Y-107.758
    X16.181 Y-107.759
    X15.742 Y-107.866
    X15.741 Y-107.866
    X15.336 Y-107.964
    X14.961 Y-108.055
    X14.96 Y-108.055
    X14.611 Y-108.139
    X14.61 Y-108.14
    X14.284 Y-108.217
    X14.281 Y-108.218
    X13.976 Y-108.29
    X13.689 Y-108.358
    X13.688 Y-108.358
    X13.416 Y-108.422
    X13.414 Y-108.423
    X13.157 Y-108.483
    X13.157 Y-108.483
    X12.912 Y-108.54
    X12.911 Y-108.54
    X12.678 Y-108.594
    X12.671 Y-108.596
    X12.449 Y-108.646
    X12.03 Y-108.74
    X12.026 Y-108.741
    X11.635 Y-108.828
    X11.627 Y-108.83
    X11.258 Y-108.909
    X11.257 Y-108.909
    X10.906 Y-108.984
    X10.896 Y-108.986
    X10.226 Y-109.122
    X10.217 Y-109.124
    X9.565 Y-109.25
    X9.554 Y-109.252
    X8.889 Y-109.373
    X8.879 Y-109.374
    X8.531 Y-109.434
    X8.526 Y-109.435
    X8.161 Y-109.496
    X8.157 Y-109.497
    X7.769 Y-109.56
    X7.764 Y-109.561
    X7.346 Y-109.627
    X7.341 Y-109.628
    X7.119 Y-109.661
    X6.886 Y-109.697
    X6.882 Y-109.698
    X6.635 Y-109.735
    X6.631 Y-109.736
    X6.37 Y-109.774
    X6.369 Y-109.774
    X6.092 Y-109.814
    X5.797 Y-109.857
    X5.794 Y-109.857
    X5.476 Y-109.902
    X5.475 Y-109.902
    X5.133 Y-109.95
    X5.131 Y-109.951
    X4.76 Y-110.002
    X4.759 Y-110.002
    X4.355 Y-110.057
    X4.353 Y-110.057
    X4.138 Y-110.086
    X3.913 Y-110.117
    X3.911 Y-110.117
    X3.673 Y-110.149
    X3.424 Y-110.183
    X3.421 Y-110.183
    X3.156 Y-110.218
    X2.878 Y-110.255
    X2.877 Y-110.255
    X2.582 Y-110.294
    X2.58 Y-110.295
    X2.268 Y-110.335
    X1.935 Y-110.379
    X1.933 Y-110.38
    X1.579 Y-110.426
    X1.2 Y-110.475
    X1.199 Y-110.476
    X0.792 Y-110.529
    X0.728 Y-110.535
    X0.663 Y-110.537
    X-0.663 Y-110.537
    X-0.728 Y-110.535
    X-0.792 Y-110.529
    X-1.199 Y-110.476
    X-1.2 Y-110.475
    X-1.579 Y-110.426
    X-1.933 Y-110.38
    X-1.935 Y-110.379
    X-2.268 Y-110.335
    X-2.58 Y-110.295
    X-2.582 Y-110.294
    X-2.877 Y-110.255
    X-2.878 Y-110.255
    X-3.156 Y-110.218
    X-3.421 Y-110.183
    X-3.424 Y-110.183
    X-3.673 Y-110.149
    X-3.911 Y-110.117
    X-3.913 Y-110.117
    X-4.138 Y-110.086
    X-4.353 Y-110.057
    X-4.355 Y-110.057
    X-4.759 Y-110.002
    X-4.76 Y-110.002
    X-5.131 Y-109.951
    X-5.133 Y-109.95
    X-5.475 Y-109.902
    X-5.476 Y-109.902
    X-5.794 Y-109.857
    X-5.797 Y-109.857
    X-6.092 Y-109.814
    X-6.369 Y-109.774
    X-6.37 Y-109.774
    X-6.631 Y-109.736
    X-6.635 Y-109.735
    X-6.882 Y-109.698
    X-6.886 Y-109.697
    X-7.119 Y-109.661
    X-7.341 Y-109.628
    X-7.346 Y-109.627
    X-7.764 Y-109.561
    X-7.769 Y-109.56
    X-8.157 Y-109.497
    X-8.161 Y-109.496
    X-8.526 Y-109.435
    X-8.531 Y-109.434
    X-8.879 Y-109.374
    X-8.889 Y-109.373
    X-9.554 Y-109.252
    X-9.565 Y-109.25
    X-10.217 Y-109.124
    X-10.226 Y-109.122
    X-10.896 Y-108.986
    X-10.906 Y-108.984
    X-11.257 Y-108.909
    X-11.258 Y-108.909
    X-11.627 Y-108.83
    X-11.635 Y-108.828
    X-12.026 Y-108.741
    X-12.03 Y-108.74
    X-12.449 Y-108.646
    X-12.671 Y-108.596
    X-12.678 Y-108.594
    X-12.911 Y-108.54
    X-12.912 Y-108.54
    X-13.157 Y-108.483
    X-13.157 Y-108.483
    X-13.414 Y-108.423
    X-13.416 Y-108.422
    X-13.688 Y-108.358
    X-13.689 Y-108.358
    X-13.976 Y-108.29
    X-14.281 Y-108.218
    X-14.284 Y-108.217
    X-14.61 Y-108.14
    X-14.611 Y-108.139
    X-14.96 Y-108.055
    X-14.961 Y-108.055
    X-15.336 Y-107.964
    X-15.741 Y-107.866
    X-15.742 Y-107.866
    X-16.181 Y-107.759
    X-16.185 Y-107.758
    X-16.418 Y-107.7
    X-16.66 Y-107.641
    X-16.914 Y-107.579
    X-16.918 Y-107.578
    X-17.186 Y-107.512
    X-17.189 Y-107.512
    X-17.469 Y-107.442
    X-17.765 Y-107.369
    X-17.765 Y-107.369
    X-18.077 Y-107.292
    X-18.079 Y-107.291
    X-18.408 Y-107.21
    X-18.754 Y-107.124
    X-19.123 Y-107.033
    X-19.124 Y-107.033
    X-19.514 Y-106.936
    X-19.929 Y-106.833
    X-19.932 Y-106.832
    X-20.372 Y-106.721
    X-20.843 Y-106.605
    X-20.846 Y-106.604
    X-21.35 Y-106.477
    X-21.615 Y-106.412
    X-21.617 Y-106.411
    X-21.893 Y-106.342
    X-21.967 Y-106.321
    X-22.312 Y-106.206
    X-22.315 Y-106.205
    X-22.648 Y-106.093
    X-22.97 Y-105.985
    X-22.971 Y-105.985
    X-23.282 Y-105.88
    X-23.583 Y-105.779
    X-23.586 Y-105.778
    X-23.878 Y-105.679
    X-23.878 Y-105.679
    X-24.435 Y-105.49
    X-24.436 Y-105.49
    X-24.96 Y-105.312
    X-24.962 Y-105.311
    X-25.456 Y-105.142
    X-25.459 Y-105.141
    X-25.926 Y-104.98
    X-25.929 Y-104.98
    X-26.372 Y-104.826
    X-26.792 Y-104.68
    X-26.794 Y-104.679
    X-27.194 Y-104.539
    X-27.195 Y-104.538
    X-27.576 Y-104.404
    X-27.578 Y-104.403
    X-27.942 Y-104.274
    X-27.943 Y-104.274
    X-28.291 Y-104.15
    X-28.294 Y-104.149
    X-28.626 Y-104.029
    X-28.945 Y-103.914
    X-28.949 Y-103.912
    X-29.255 Y-103.8
    X-29.256 Y-103.8
    X-29.55 Y-103.692
    X-29.553 Y-103.691
    X-29.837 Y-103.586
    X-29.84 Y-103.585
    X-30.377 Y-103.384
    X-30.382 Y-103.382
    X-30.884 Y-103.191
    X-30.891 Y-103.188
    X-31.362 Y-103.005
    X-31.366 Y-103.004
    X-31.811 Y-102.829
    X-31.815 Y-102.827
    X-32.237 Y-102.659
    X-32.245 Y-102.656
    X-32.646 Y-102.492
    X-32.649 Y-102.491
    X-33.032 Y-102.332
    X-33.042 Y-102.328
    X-33.409 Y-102.173
    X-33.413 Y-102.171
    X-33.767 Y-102.019
    X-33.774 Y-102.016
    X-34.116 Y-101.866
    X-34.119 Y-101.864
    X-34.451 Y-101.717
    X-34.463 Y-101.712
    X-35.101 Y-101.419
    X-35.113 Y-101.413
    X-35.725 Y-101.122
    X-35.739 Y-101.116
    X-36.334 Y-100.822
    X-36.346 Y-100.816
    X-36.932 Y-100.517
    X-36.944 Y-100.51
    X-37.528 Y-100.202
    X-37.54 Y-100.196
    X-38.129 Y-99.875
    X-38.14 Y-99.869
    X-38.741 Y-99.532
    X-38.751 Y-99.526
    X-39.37 Y-99.17
    X-39.378 Y-99.165
    X-39.697 Y-98.978
    X-39.701 Y-98.975
    X-40.028 Y-98.781
    X-40.033 Y-98.778
    X-40.369 Y-98.576
    X-40.373 Y-98.574
    X-40.719 Y-98.364
    X-40.723 Y-98.361
    X-41.08 Y-98.142
    X-41.083 Y-98.139
    X-41.453 Y-97.91
    X-41.457 Y-97.908
    X-41.841 Y-97.667
    X-41.844 Y-97.665
    X-42.244 Y-97.413
    X-42.247 Y-97.411
    X-42.664 Y-97.145
    X-42.667 Y-97.143
    X-43.105 Y-96.862
    X-43.108 Y-96.86
    X-43.567 Y-96.563
    X-43.57 Y-96.561
    X-44.054 Y-96.245
    X-44.056 Y-96.244
    X-44.568 Y-95.908
    X-44.57 Y-95.907
    X-44.837 Y-95.731
    X-44.839 Y-95.73
    X-45.114 Y-95.548
    X-45.115 Y-95.547
    X-45.399 Y-95.359
    X-45.401 Y-95.358
    X-45.694 Y-95.163
    X-45.695 Y-95.162
    X-45.998 Y-94.96
    X-45.999 Y-94.959
    X-46.313 Y-94.749
    X-46.314 Y-94.749
    X-46.639 Y-94.531
    X-46.64 Y-94.53
    X-46.977 Y-94.304
    X-46.978 Y-94.304
    X-47.327 Y-94.068
    X-47.328 Y-94.068
    X-47.691 Y-93.823
    X-47.692 Y-93.822
    X-48.069 Y-93.567
    X-48.07 Y-93.567
    X-48.463 Y-93.301
    X-48.463 Y-93.3
    X-48.873 Y-93.022
    X-48.873 Y-93.022
    X-49.3 Y-92.731
    X-49.301 Y-92.731
    X-49.747 Y-92.427
    X-49.748 Y-92.426
    X-50.214 Y-92.108
    X-50.215 Y-92.107
    X-50.703 Y-91.773
    X-50.704 Y-91.773
    X-51.216 Y-91.422
    X-51.217 Y-91.422
    X-51.755 Y-91.052
    X-51.755 Y-91.052
    X-52.321 Y-90.663
    X-52.322 Y-90.663
    X-52.918 Y-90.253
    X-52.918 Y-90.252
    X-53.228 Y-90.039
    X-53.229 Y-90.038
    X-53.547 Y-89.819
    X-53.548 Y-89.818
    X-53.876 Y-89.592
    X-54.213 Y-89.359
    X-54.213 Y-89.359
    X-54.56 Y-89.119
    X-54.56 Y-89.119
    X-54.918 Y-88.872
    X-54.918 Y-88.872
    X-55.286 Y-88.618
    X-55.286 Y-88.618
    X-55.666 Y-88.355
    X-55.666 Y-88.355
    X-56.057 Y-88.084
    X-56.057 Y-88.084
    X-56.461 Y-87.805
    X-56.461 Y-87.804
    X-56.877 Y-87.516
    X-56.878 Y-87.515
    X-57.308 Y-87.217
    X-57.753 Y-86.909
    X-57.753 Y-86.908
    X-58.213 Y-86.589
    X-58.213 Y-86.589
    X-58.689 Y-86.258
    X-59.182 Y-85.916
    X-59.182 Y-85.916
    X-59.692 Y-85.561
    X-59.692 Y-85.561
    X-60.222 Y-85.193
    G2 X-60.584 Y-84.731 I0.571 J0.821
    G1 X-60.651 Y-84.558
    X-60.712 Y-84.398
    X-60.826 Y-84.107
    X-60.926 Y-83.851
    X-61.016 Y-83.623
    X-61.098 Y-83.418
    X-61.173 Y-83.234
    X-61.241 Y-83.066
    X-61.305 Y-82.913
    X-61.364 Y-82.772
    X-61.419 Y-82.644
    X-61.52 Y-82.41
    X-61.611 Y-82.206
    X-61.695 Y-82.025
    X-61.774 Y-81.862
    X-61.847 Y-81.715
    X-61.987 Y-81.446
    X-62.284 Y-80.938
    X-62.443 Y-80.691
    X-62.632 Y-80.414
    X-62.737 Y-80.265
    X-62.855 Y-80.102
    X-62.986 Y-79.924
    X-63.134 Y-79.726
    X-63.303 Y-79.505
    X-63.395 Y-79.384
    X-63.495 Y-79.255
    X-63.604 Y-79.116
    X-63.721 Y-78.967
    X-63.848 Y-78.805
    X-63.987 Y-78.63
    X-64.14 Y-78.438
    X-64.307 Y-78.228
    X-64.493 Y-77.996
    X-64.7 Y-77.739
    X-64.813 Y-77.599
    X-64.932 Y-77.452
    X-65.059 Y-77.295
    X-65.194 Y-77.128
    X-65.338 Y-76.95
    X-65.492 Y-76.761
    X-65.658 Y-76.557
    X-65.809 Y-76.371
    X-68.484 Y-73.589
    X-68.537 Y-73.529
    X-73.324 Y-67.669
    G2 X-73.549 Y-66.993 I0.774 J0.633
    X-67.523 Y85.635 I73.549 J73.529
    G1 X-70.77 Y89.438
    M5
    M5
    M30
    Thanks for help\
    Max
  2. Misterg
    Misterg Veteran
    If you look at the code, the non-circular part of the cut has ~700 points! It is just overloading the controller.
    (From NCViewer)
    What settings are you using for the toolpath in F360? Do you have 'Smoothing' enabled? Try it if not, or make the accuracy larger.
