Software problem
Discussion in 'Control Software' started by Mihai Pintea, Mar 4, 2023.
  1. Mihai Pintea
    Hi .
    Recently I bought a lead 1010 Machie, I assembled it and I have problems with installation. I have downloaded software from openbuilds.com and when to select I need, I do not appear the Com27 option, only the com3 option appears. Why don't I have that Com27 option for blackbox ?
    Thank you
  2. sharmstr
    Dont worry about the COM numbers. Select whichever COM port that your blackbox is connected to. If you installed the drivers the name will start with FTDI USB to serial COM<whatever com port yours is on>
    Alex Chambers likes this.
  3. Mihai Pintea
    Sounds perfect . Thank you very much for your help !!!
  4. Mihai Pintea
  5. Mihai Pintea
    I installed everything and connected the software but the machine does not move. . it makes a sound as if something is stuck. it does not move in any direction
    #5 Mihai Pintea, Mar 4, 2023
  6. sharmstr
  7. Mihai Pintea
    I checked the wires and everything is connected correctly. The X and Y axes are more difficult to move by hand than the Z axis. I disconnected the motors from the threaded bar and tried to see if the motors work like this. the engines do not work even if they are disconnected
  8. sharmstr
  9. sharmstr
    Also, for a sanity check, did you pick a machine profile in the grbl settings tab? It could be that your machine doesnt have the correct settings.
  10. Akmal Abdullayev
  11. Akmal Abdullayev
  12. Peter Van Der Walt
    Fluid NC in CONTROL is not ready for prime time yet. See FluidNC support · Issue #283 · OpenBuilds/OpenBuilds-CONTROL
    Spindle rpm, jog distances all those need one of the uncompleted tasks (parsing configs).
    When FluidNC is completely implement we will send out announcements, and updated documentation, for now its in development and testing still. Only grbl and grblHAL are supported.
    Follow the GitHub Issue above for updates when the developers implement milestones.
