Solid V-Wheel get stuck when tightened
Discussion in 'General Talk' started by Eduardo Moreno, Nov 7, 2019.
  1. Eduardo Moreno
    Hello!
    I am making the assembly shown in the picture, but when I tighten the nut, the v-wheel get stuck.
    Thank you very much.
  2. jeffmorris
    jeffmorris Journeyman
    Did you put the washer between the bearings? Bearing - washer - bearing?
    Note: not a washer, it's a Precision Shim : Precision Shim - 10x5x1mm
    They are machined to an exact thickness to carry the forces on the center hubs of the bearings, while the wheel rides on the outer rims of the bearings. Without the shim in place you are effectively pushing the bearing races themselves apart
    Watch:
  4. jeffmorris
    I couldn't remember what the parts that go between bearings are called.
  5. Eduardo Moreno
    Thanks very much, jeffmorris and Peter.
    Yes, I put the Precision Shim between the bearings.
  6. Christian James
    Christian James Journeyman
    Did you also put a precision shim between the eccentric and the wheel?
  7. Rick 2.0
    If it doesn't work with the precision shim properly in place you may have defective parts. Contact the seller for resolution.
  8. Eduardo Moreno
    Thanks very much for you answer, Christian.
    Yes, I also put a precision shim between the eccentric and the wheel.
  9. Eduardo Moreno
    Thanks very much for your answer, Rick.
    I will contact the seller.
