squaring the z axis on a 1515
Discussion in 'CNC Mills/Routers' started by shotfun, Mar 6, 2022.
  1. shotfun
    shotfun New
    the top of my z axis is kicked right a bit. ive been checking out the forum and can't find an easy fix to this. any ideas? thanks
  2. Gary Caruso
    Hi Shotfun, can't you simply loosen your x gantry carriage plate at the black angle corner connectors and square as needed?
    at about 51min
    Gary
    #2 Gary Caruso, Mar 6, 2022
  3. shotfun
    shotfun New
    hey gary, thanks a bunch. for some reason im having a bit of an issue with opening that link. is it these connectors here in red? can it help doing the ones in yellow? im not front of the machine right now but I thought the right side counterparts to the bolts had concentric spacers. as far as the video goes can you try reposting here or maybe just the user and the video title. I can go from there. thanks a ton
  4. Gary Caruso
    Sorry about that, I updated the link its just the build video, yes the ones in Red, make sure that vertical C-beam is square first then adjust your router mount until your trimming is square.
    Gary
  5. shotfun
    shotfun New
    Don’t be sorry at all. Glitches in the matrix ya know… thanks so much for your help. I’ll report back. Have a great day.
    Gary Caruso likes this.
